runs like a 4 cyl burns like a 8cyl
73,512 MILES
PICKME2ASK
my 95 golf mk3 73k automatic 4 cyl gas its burning soo much gas and it feels like
i dont have enough power specially when im going down hill it feels
like a downshift to 1st its seems like the car automatically brakes for it self
and it dosent seem to be released until im at ground level when the check engine turns on while in the freeway going 65mph the cars runs ugly like it lacks of power and control sees rough seconds later the engine light turns off the car gains alot amount of power even feels like it has turbo in it and it uses like a gallon of water a week which is alot and its giving me 11 mpg or less
Jun 20, 2013 at 12:25 PM
EXOVCDS
  • 1,882 POSTS
Scan for stored ECM & TCM codes.
Could be a temperature sensor fault, O2 sensor fault, fuel pressure regulator fault, plugged catalytic converter fault etc.
Coolant leak may or may not be related (probably not)... usual leak areas, plastic coolant flange, water pump, radiator, heater core etc.
Thomas
Jun 22, 2013 at 3:17 AM
