Runs lean
180,000 MILES • 1.6L • 4 CYL • FWD • MANUAL
ZEMORZEMOR
  • 486 POSTS
At idle long term fuel trim vary for 6.3 % to sometimes 14.2%. what could cause the problem?
May 14, 2017 at 12:10 AM
HMAC300
  • 48,601 POSTS
vacuum leak, low fuel pressure leaky injector etc. scan for codes and check fuel pressure with a gauge. See link. auto parts rent gauge.
May 14, 2017 at 1:46 AM
ZEMORZEMOR
  • 486 POSTS
i forgot to tell you the oxygen sensor stays lean after i shut off the engine and started back .it will oscillate after i bleep the gas pedal
May 15, 2017 at 8:53 AM
HMAC300
  • 48,601 POSTS
check what I said in first reply
May 15, 2017 at 9:36 AM
