Engine will not stay running
145,000 MILES • 6 CYL • 4WD • AUTOMATIC
PAUL ANDERSON2
  • 6 POSTS
it runs for 5-10 seconds and shuts off. will instant restart.. replaced fuel pump, no change. will run on ether, great fuel pressure.. no codes on scanner. if you pump the gas pedal fast it will stay running for 10-20 seconds longer before it struggles and shuts off. no check engine light, good pressure to the fuel rails..
Sep 25, 2020 at 6:04 AM
  • 110,248 POSTS
You mentioned it stays running on ether (starting fluid). Can you keep it running for a long time with it? If so, it sounds like you may be losing the injector pulse (based on the fuel pressure at the rail is good).
If you can't keep it running with ether, then my first suspect is the crankshaft position sensor. It can fail causing the loss of ignition spark. Interestingly, it doesn't always set a code. Take a look through this link and let me know if it seems to mirror what you are experiencing.
Let me know. I'll watch for your reply.
Sep 25, 2020 at 1:26 PM
PAUL ANDERSON2
  • 6 POSTS
We use a burnable brake cleaner (less chance of ruining parts) and yes you can drive the vehicle across the lot as long as you spray cleaner in it... uses a lot of spray. But we got it on the hoist so we could change the fuel pump and then used it to drive off the rack to put it back out in the lot until we have a chance to work on it again.
Sep 25, 2020 at 1:53 PM
  • 110,248 POSTS
What is the fuel pressure? It almost sounds like it's too high and causing an issue.
Fuel Pressure (Key ON, Engine OFF) .................... 345-395 kPa (50-57 psi)
Sep 25, 2020 at 2:30 PM
PAUL ANDERSON2
  • 6 POSTS
fuel pressure right on target numbers... Mass air flow sensor is reading 1.97 on start up even if it is or isn't plugged in. we are ordering a new one.. kind of weird that it doesn't give a code. but we have heard of this before with another Trailblazer.
Sep 28, 2020 at 6:37 AM
  • 110,248 POSTS
That certainly could be an issue. However, you indicated the fuel pressure was within spec originally. Are you sure the pump isn't turning on?
Sep 28, 2020 at 11:16 AM
PAUL ANDERSON2
  • 6 POSTS
it is working. also brand new fuel pump was installed and still acts the same way.. we are going to replace the mass air flow sensor, hope it works.. we will let you know.. The reason we replaced the fuel pump at first was because we thought that the pump might be losing power after start up. and/or lots of water/crud in the fuel tank.. so we replaced and cleaned the tank.. no water, no crud.. really clean tank. so we replaced the fuel pump and it still ran like it does. runs for 5 seconds and then it chugs and shuts off. It's my daughters rig and it has to run good.. I'm a retired mechanic and the shop i used to work at is fixing the Trailblazer..
Sep 28, 2020 at 4:53 PM
  • 110,248 POSTS
If the tank was dirty, did you check the injectors? Also, let me know about the mass air flow sensor.
Sep 29, 2020 at 12:02 PM
PAUL ANDERSON2
  • 6 POSTS
Mass air flow sensor did the trick.. we figured with the reading the same at 1.97 whether unplugged or plugged in when started.. had to be some thing not right... with the new one in it was reading 7.90 ish.. and running like a top.. the tank when we changed the fuel pump was clean as a whistle.. it was not dirty, Just like I said.. No crud in the tank.. So, no codes and won't run after start up.. Check the Mass air flow sensor.. if the sensor reads the same if unplugged as it does when plugged in.. save some major cash and try replacing it first, before trying the fuel pump.
Sep 29, 2020 at 3:33 PM
  • 110,248 POSTS
Glad to hear you got it working right. Let us know if you have questions in the future.
Sep 30, 2020 at 10:31 AM
