I put a coil pack on cylinder eight and eight new plugs on. Also an idle air control. Now it runs at 2,000 RPM's. What is wrong?
Jul 28, 2018 at 6:31 AM
✓Experienced Mechanic
First did you install OEM plugs? If not change them all out. I know it sounds strange but factory plugs have a particular resistance which will change the spark timing. Also, I would service the throttle bore. Here are guides that should help:
