When the engine temperature gets around 160 degrees the truck will shift gears at very low speed. It will go into overdrive at 45 mph and have a tremendous loss in power. It will not down shift when climbing a steep incline at low speed unless you stomp the gas pedal or down shift manually. It will spark knock and smoke when accelerating. I have changed out the following parts:
Map Sensor
EGR Solenoid
EGR Valve
Oxygen Sensor
Coolant temperature Switch
Coolant Temperature Sensor
Ignition Coil
Ignition coil module
Throttle position sensor
Distributor Cap
Rotary button
Fuel injectors
Throttle body rebuild kit
Transmission filter
If I take the thermostat out it runs and shifts good. Any help will be greatly appreciated.
Map Sensor
EGR Solenoid
EGR Valve
Oxygen Sensor
Ignition Coil
Distributor Cap
Rotary button
Fuel injectors
Transmission filter
Nov 9, 2019 at 8:03 AM
