Running very rough after intake manifold replacement
150,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
V SHIRK
Intake manifold had a crack leaking a small amount of antifreeze towards front of motor. Replaced intake manifold with a brand new one. Since replacing, car runs very rough, though all injectors are working as well as coils. Car ran amazingly smooth before swap. Any ideas? Definitely not a first timer on turning wrenches but I am stumped.
Dec 10, 2021 at 9:04 AM
  • 110,248 POSTS
Are there any diagnostic trouble codes? What you described sounds like a simple engine vacuum leak. Have you checked and confirmed there are none? See link below.
Also, there was a TSB on the first runner coolant cross-over related to leakage. Is that where the problem was?
Dec 10, 2021 at 1:14 PM
V SHIRK
Thanks guys! I put a set of ignition coil boots in this morning and problem solved. I appreciate you taking the time to help me out.
Dec 11, 2021 at 8:03 AM
  • 110,248 POSTS
You are very welcome. I'm glad to hear it's running properly again.
Please feel free to come back anytime in the future if you have questions.
Dec 11, 2021 at 2:09 PM
