Running very rough
176,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
ONEGOODWOP
Idles rough runs rough at low rpm's and less rough at higher rpm's. Lots of carbon blowing out exhaust pipe and fuel dumping out of injectors. I have changed rotor, cap, plugs and mass airflow sensor. Used my code reader (blinking service engine soon light) and got code 22 and 54. Just had a new catalytic converter and muffler installed after being tested and found to be all plugged up.
Aug 14, 2017 at 8:59 AM
  • 55,781 POSTS
It sounds like the ECM is bad. Here is the location so you can swap it out with a used one you can get pretty cheap.
Cheers, Ken
Aug 16, 2017 at 6:24 AM
ONEGOODWOP
Thank you for the reply Ken. I was told by a shop after they did a compression check I have a bad cylinder or even a bent lifter. They were going to remove valve cover to determine.
Aug 19, 2017 at 2:49 AM
  • 55,781 POSTS
Cheers, Ken
Aug 19, 2017 at 3:59 AM
