Running Tail Lights not working?
135,000 MILES • 5.0L • AUTOMATIC
JEREMY_MCNEILL
I am having erratic behavior with my tail lights. All the bulbs seem intact. Sometimes both blinkers will work, sometimes only one. The brake lights work and the reverse lights work sometimes. But the tail lights do not turn on when I turn on the running lights. There is an aftermarket towing package on the truck, and so there is an additional wiring harness. I did notice that there is a white wire that is hanging loose from a metal o ring, so I think it might have got cut at some point. Would that mess up the whole rear tail light system if the tow light ground is out? Or is there something else I need to look for.
Sep 18, 2026 at 10:32 AM
MECHTRIX
  • 581 POSTS
Yes I'd start there with the wire you found and while your in there id look around you never know what else you might find ..but yes a ground issue is vary likely the cause of the lights not working ...I think youre on the right track good looking out ..best of luck hope this helps
Sep 18, 2026 at 3:02 PM
KRAKENAUTO
  • 111 POSTS
I agree with Mechtrix. I'd reconnect that wire to a good ground spot and see if that resolves your issue, as a bad ground will definitely cause the issue you state.
Oct 4, 2026 at 7:11 AM
