Running rough at high gear 50 mph
1999 FORD E-SERIES VAN
120,000 MILES • 5.4L • V8 • 2WD • AUTOMATIC
SAMANTHA DELIMA
Engine starts cutting out at 50 mph. Cleaned injectors, replaced mas, now running worse. ideas?
Jan 9, 2019 at 10:52 AM
  • 110,244 POSTS
If the check engine light is staying on when the engine is running, I would first scan the computer for diagnostic trouble codes. Here is a quick video showing how it is done:
https://youtu.be/YV3TRZwer8k
Next, I would recommend confirming the the fuel pump pressure is within the manufacturer's specs. Here is a link that shows in general how to check it:
I attached the manufacturer's specifications for you.
Start with this and let me know what you find.
Jan 10, 2019 at 10:33 AM
