Running rough
75,000 MILES • 2.3L • V6 • 2WD • AUTOMATIC
SHARON COOKE
Suddenly running rough with a fair bit of smoke n strong smell of fuel. Starts easily but check engine came on and couldn't cancel alert for it.
Aug 24, 2019 at 10:19 PM
  • 55,732 POSTS
It sounds like an injector is stuck on could have shorted out etc. You should be able to remove all spark plugs and the cylinder with the wet/black plug will be the culprit. Here is a guide to help you test the injector once you have removed it:
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Aug 26, 2019 at 8:25 AM
SHARON COOKE
Hi Ken, thanks for your reply. It has been diagnosed as cylinder 4 misfire. How is this repaired and is it expensive as I am on a pension?
Aug 27, 2019 at 5:42 PM
  • 55,732 POSTS
The first thing we need to do is remove the spark plug and look at it then do a compression test. here are two guides to help us:
https://www.2carpros.com/articles/how-to-change-spark-plugs
and
Aug 29, 2019 at 2:49 AM
