Engine running rich at idle in closed loop
82,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
AARON N
  • 7 POSTS
all new gaskets on top of motor, MAP-EGR-injectors-plugs-coil, many new parts. can't find any major vacuum leaks. had to pull all 4 new 02 sensors black with soot. good power when driving on an open road, but when engine is warmed up put in park, surges at idle. 1132- 1152 bank one and two rich. don't know what to do!
Jan 6, 2022 at 4:33 AM
  • 110,248 POSTS
High fuel pressure can cause a rich mixture. Have you checked fuel pressure to see if it is within the manufacturer's specifications? If not, I would start there. Here is a link showing how in general it's done:
Next, a faulty coolant temperature sensor can also cause this type of issue. The vehicle's computer (PCM) receives a signal from the CTS indicating coolant temperature. If the sensor indicates it is -40 degrees below 0, the PCM will dump fuel to allow the engine to run in extreme conditions such as this. However, the PCM doesn't realize the sensor is wrong and doesn't set a code.
So, if you have a live data scan tool, before starting the engine, see what the signal from the ECT is. It should be really close to ambient temperature. You may want to inspect the connector at the ECT sensor and inspect it for corrosion, damage, or a bad connector. I attached 2 pics below showing the sensor location.
Let me know what you find.
Jan 6, 2022 at 9:27 AM
AARON N
  • 7 POSTS
Funny the coolant sensor was only thing left not replaced, did lower one when doing intake still surging when in closed loop, don't know what to do. fuel pressure 40. Thanks for your help. cats?
Jan 8, 2022 at 6:28 AM
  • 110,248 POSTS
Did you replace the temperature sensor? If you did, have you done a leak-down test on fuel pressure? You may have an injector leaking.
Basically, a leak down is when the pump is turned off. Pressure will drop a little but should take a little time and shouldn't happen really fast.
Jan 8, 2022 at 3:30 PM
AARON N
  • 7 POSTS
yes, put in new coolant sensor, no change, fuel pressure is 39 to 40 at idle to highway speed with live data. But I did find muffler may be plugged hotter in front than in back. Original muffler is 20 years old. New one on its way! I will let you know. Thanks, Aaron.
Jan 9, 2022 at 10:13 AM
  • 110,248 POSTS
Is it possible for you to provide me with the short-term fuel trims? Fuel pressure is good, and a vacuum leak won't cause a rich mixture. Also, let me know if you have checked the catalytic converters. As far as the muffler is possible, so let me know what you find.
Jan 10, 2022 at 7:10 AM
AARON N
  • 7 POSTS
Joe, took some time to get this done but the rear cat is on the garage floor plugged 90% I thought it was muffler wrong. I really missed it on this one, the end is near. Will give final report when done. Thanks, Aaron
Jan 14, 2022 at 10:01 AM
  • 110,248 POSTS
I had a feeling if it was exhaust related, it would be the converter. However, when you mentioned the muffler, I was thinking anything is possible.
Thanks for the update. It's appreciated. Let me know how things turn out for you.
Jan 14, 2022 at 1:15 PM
AARON N
  • 7 POSTS
This is not going well, the rear cat was plugged so I replaced it, engine still surging. All that`s left is the fuel system, fuel pump- fuel regulator? has new injectors, fuel filter looked original when I replaced it. Fuel pressure is always 39 to 40 on live data, fuel pressure gauge won`t fit orifice on fuel rail. The upstream 02`s are at 1mv . not switching. Any input I would be grateful again. Thanks Joe.
Jan 19, 2022 at 4:46 AM
  • 110,248 POSTS
If the 02 sensors aren't switching, chances are either they are bad, there is too much resistance in the wiring, or there is an issue at the connector. If it was a downstream sensor, I would say the converter isn't working properly and there is little to no change in oxygen level readings
These are new sensors, correct?
Jan 19, 2022 at 5:59 AM
AARON N
  • 7 POSTS
Yes, o2`s are new, all four.
Jan 19, 2022 at 7:57 AM
  • 110,248 POSTS
With your scan tool or a voltmeter, try this test and let me know if you see voltage changes from the sensor.
https://www.2carpros.com/articles/how-to-test-an-oxygen-sensor-02-sensor
If you have already done this, let me know. Also, let me know any specific codes you have retrieved since the exhaust work.
Jan 19, 2022 at 10:15 AM
AARON N
  • 7 POSTS
Subzero weather making it slow going, found fuel pressure and gauge fitting to work on ford fuel rail, 30 PSI. pull off vacuum line from fuel pressure sensor goes up to 39 put back on back to 30. Bad fuel pump? live data said 40 all the time, that's why I never checked the fuel rail. This has to be it! Thanks again for your input.
Jan 26, 2022 at 2:25 AM
  • 110,248 POSTS
It's on the low end, but still within spec. The manual gauge is usually 5 to 7 PSI lower than a scan tool.
Have you ever checked the short-term fuel trims? I mentioned it right before you noticed the converter issue.
Let me know,
Jan 26, 2022 at 9:01 AM
