Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
1500
Engine
Symptoms
Rich
Running rich
1995 CHEVROLET 1500
165,000 MILES • 5.7L • V8 • 2WD • MANUAL
JACKNUT
MEMBER
Seems to run rich more power at high rpm's. I changed throttle body and put in a known good temperature sensor.. any ideas? Thanks
Aug 8, 2019 at 7:02 PM
Experienced Mechanic
These truck had problem with the EGR valve. lets remove it to check the valve. here is a video to show you how and a guide that can help as well:
https://youtu.be/DqUCbbKdWf4
and
https://www.2carpros.com/articles/engine-has-low-power-output
Aug 10, 2019 at 7:07 AM
Add image or video
Ask a new question
Engine won't start
Transmission — Not Shifting
