Will not stay running
53,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
VIPERIV
I can start my car it will run a few moments then shut off. Start it up again shuts off won't start again unless it sit for awhile. I replaced the fuel pump relay. Thinking fuel pump?
Dec 1, 2019 at 1:50 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
I would definitely check the fuel pressure. I would some how put a mechanical fuel gauge in the fuel line to test the fuel pump output.The fuel pressure p.s.i. specification is 9-13 p.s.i. Let me know if you have any further questions.Hope this helps and thanks for using 2CarPros.
Dec 1, 2019 at 11:23 AM
