Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Oldsmobile
Delta 88
Engine
Symptoms
Misfire
running on 3 cylinders
1986 OLDSMOBILE DELTA 88
112,000 MILES
JBAALMANN
MEMBER
1 POST
replaced coil pack module spark plugs and wires no spark on 3 cylnders.
May 17, 2013 at 1:48 PM
ERNEST CLARK
Experienced Mechanic
From the beginning, what directed you to a "No spark" condition on cylinder 3?
How are you checking for the "No spark" condition on cylinder 3?
Did you use dailectric grease inside the plug boots on both ends?
Also, check the wiring/connectors leading to the coil pack, specifically for that cylinder.
Jun 11, 2013 at 4:54 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
