Running lights, dash lights and rear window button not working
KKLENNER
  • 1995 TOYOTA 4RUNNER
  • 3.0L
  • 6 CYL
  • 4WD
  • 210,000 MILES
Hello, I need help with figuring out how to fix running lights, dash lights and rear window with front switch.
Truck was standing for couple weeks, when I started it all rear lights, dash and rear window did not work.
Changed all fuses and turning lights and brake lights came back, rear window works with key but not with front switch.
Cannot figure out why running lights, dash and rear window with switch does not.
Hoping you can help me?
Thank you so much!
Katie
Monday, December 11th, 2017 AT 11:31 AM
STEVE W.
  • 13,573 POSTS
If they were working prior to it being parked my first thought is that rodents got to the wiring and chewed on it or there is a bad connection.
A good visual inspection of the wiring harness would be a start.
Thursday, December 14th, 2017 AT 7:36 PM
