So yesterday I changed my fuel injectors, ignition coils, and spark plugs due to a misfire I was having. I previously replaced the fuel pump along with the mass air flow sensor and PCV valve. But after changing the injector spark plugs and coils code P0174 and P0171 popped up. There was a previous O2 sensor code present before changing everything. So was there something I possibly did wrong to cause the truck to run lean all of a sudden?
May 6, 2020 at 9:47 AM
