My 02 sensors are not reading causing my car to run lean. What could it be.
Feb 2, 2016 at 2:36 AM
HMAC300
✓Experienced Mechanic
check fuel pressure with a gauge autoparts rent it.
Feb 2, 2016 at 4:08 AM
BEN95
MEMBER
And it also seems likes its misfiring at idle
Feb 2, 2016 at 4:23 AM
HMAC300
check for a vacuum leak as well then have it scanned for codes.
Feb 2, 2016 at 4:27 AM
BEN95
MEMBER
I scanned it and no codes come up. But it does sound like a slight air leak coming from the backside of the plastic upper intake. But sprayed with brake clean and no difference in idle
