While driving the engine shuts off for a second?
278,656 MILES • 2.0L • 4 CYL • 2WD • MANUAL
DANIEL
While I'm driving with my foot on the accelerator my truck will cut off for a second each time it happens. What could be the issue?
Oct 2, 2023 at 10:29 AM
  • 110,246 POSTS
You indicated, "my truck will cut off for a second each time it happens." Is the truck cutting off the issue or does something happen and then the truck cuts off?
Let me know. However, if it is the cutting off, that sounds like an engine misfire. When was the truck last tuned up? Take a look through this link, you may find it helpful:
https://www.2carpros.com/articles/symptoms-of-engine-misfires-a-step-by-step-guide
Oct 2, 2023 at 1:49 PM
DANIEL
No nothing happens beforehand. Yes it's overdue for a tune-up!
Oct 3, 2023 at 8:08 AM
  • 110,246 POSTS
Not being there makes it difficult for me to be certain, but based on the issue, I would at a minimum remove the spark plugs for inspection. See what condition they are in. If they appear worn, I would replace them with the spark plug wires, distributor cap, and rotor button.
https://www.2carpros.com/articles/how-to-tune-up-a-car-engine
Also, if you remove them, take a few pics of them, and upload them for me to see.
Oct 3, 2023 at 12:06 PM
