I have the car listed above with a SOHC engine. My radiator and water pump has 32,000 miles on it as does the timing belt. Since day one, the temperature gauge on the dash has read the same showing 1/4 from cold mark, but as of last week i noticed that while driving at highway speeds the temperature gauge has been rising to 3/4 mark on the gauge. The issue is that the gauge then drops to the regular 1/4 mark, then goes up again to the 3/4 mark, then cools down again to the 1/4 mark.
Then i noticed with the engine hot after driving i went to gas up, i shut the motor off to fill up which took maybe ten minutes. When i got in the car and turned the key to the accessory position the gauge pegged to extreme hot scale on the gauge, but once i turned the motor on, within ten seconds the gauge settled at normal 1/4 warm on the gauge. What could be the culprit?
May 23, 2019 at 3:31 PM
