My car is running hot even when heater is not on. And no antifreeze in floorboard. It has clean oil and plenty of water. help please.
Dec 31, 2017 at 6:28 AM
✓Experienced Mechanic
Good evening.
You may have a thermostat that is stuck closed. If it does not open, no coolant will circulate and the motor will run very hot.
Dec 31, 2017 at 7:04 AM
PATENTED_REPAIR_PRO
Make sure the electric cooling fan/s run when the engine gets hot.
Dec 31, 2017 at 7:08 AM
MISSCAREYBABY
MEMBER
The hoses are not hard when I squeezed them.
Dec 31, 2017 at 9:09 AM
okay, is the engine cold or hot?
Dec 31, 2017 at 9:17 AM
PATENTED_REPAIR_PRO
If the engine is hot and the hoses are soft, you have air in the system. First make sure the cooling system is full when cold so be careful when opening the cap, let it cool back down for an hour or two first.
