Running hot
180,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
CITIZENQUASAR
The fans did not turn on when I bought this. I hard-wired them through a toggle switch to the battery. I also replaced the radiator fan control relay near the radiator and checked that the one in the fuse box was good. It still runs hot and the block especially gets hot. Any suggestions will be helpful.
Aug 7, 2019 at 3:22 PM
SCGRANTURISMO
  • 4,897 POSTS
This could be a problem with your vehicle's thermostat. The thermostat let's the coolant get to a certain temperature before opening and letting the coolant circulate to cool. This is done so that your vehicle will have a heater and defroster. If it gets stuck in the closed position, the coolant won't be allowed to circulate and your engine will overheat. Here are a couple of links for you to go to below:
https://www.2carpros.com/articles/how-an-engine-thermostat-works
Please go through these guides and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
Aug 7, 2019 at 6:07 PM
