Running hot
160,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
JAMIELAWHORN
If my car is setting it does not run hot but if I drive it about ten miles it starts to overheat. I by passed the heater core and it still ran hot so I cut the heat on and it stopped. what could it be?
Mar 7, 2019 at 2:11 AM
SCGRANTURISMO
  • 4,897 POSTS
This could be a problem with your thermostat. I have included a couple of links down below.
https://www.2carpros.com/articles/how-an-engine-thermostat-works
Please go through them. If after replacing the thermostat your vehicle is still overheating then please go to these links down below.
https://www.2carpros.com/articles/water-pump
https://www.2carpros.com/articles/symptoms-of-a-bad-water-pump
https://www.2carpros.com/articles/water-pump-replacement
Either way please get back to us with what you find out.
Thanks,
Alex
2CarPros
Mar 7, 2019 at 5:37 AM
JAMIELAWHORN
So I ended up trying everything I could think of. Thermostat, by passed the heater core, block test, (I think that's what it's called.) Changed the hoes to everything I thought would leak, changed cap, finally I went to parts store and got a flush out kit. Done that to flush cooling system no problem with overheating. Thank goodness. Thanks for your comments and helping.
Mar 9, 2019 at 4:43 AM
  • 55,542 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Mar 11, 2019 at 4:01 AM
