running hot
27,368 MILES • 3.4L • 6 CYL • FWD
GLINDA
We have put new radiator, water pump, and thermostat still running hot like red line, no water coming out of tail pipe we are at a lost. Help please.
Mar 13, 2016 at 12:17 PM
CJ MEDEVAC
  • 11,000 POSTS
AND YOUR COOLING FANS ARE COMING ON?
THE MEDIC
Mar 13, 2016 at 1:07 PM
GLINDA
Yes both
Mar 13, 2016 at 1:32 PM
CJ MEDEVAC
  • 11,000 POSTS
IS IT POSSIBLE THAT YOUR RADIATOR HOSE(S) COULD BE SUCKING FLAT?
OTHER THAN THAT, MAYBE A HEAD GASKET ISSUE?
I FOUND AN INEXPENSIVE COMBUSTION GAS CHEMICAL TEST FOR YOU
https://www.youtube.com/watch?v=a3J00_e7fyo
THERE ARE OTHER TESTS YOU CAN GET, MOST ARE OVER $50 THAT I HAVE SEEN, AND OF COURSE THERE'S THE LET SOMEONE ELSE CHECK IT OPTION
THE MEDIC
Mar 13, 2016 at 1:53 PM
