running bad
2001 CHEVROLET VENTURE
200,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
DMSTILL
the van its hard to start the fuel goes right tho filter but its back firing,missing and the exhaust is turning red
Jan 4, 2016 at 3:52 PM
WRENCHTECH
  • 20,761 POSTS
Sounds like you have a bad misfire for some reason. Start out having the code read and see if they can isolate which cylinders.
Jan 4, 2016 at 6:04 PM
DMSTILL
ya and it has new plugs and wires it was sitting for 5 months i guess
Jan 4, 2016 at 6:14 PM
WRENCHTECH
  • 20,761 POSTS
If you changed the wires, you'd better double check your firing order. Could have a bad coil too.
Jan 4, 2016 at 6:17 PM
DMSTILL
what happen is iam getting it from my brother he did plugs and wires then his girlfriend ran it out of gas at home and they just let it sit they say it ran good when it ran out gas
Jan 4, 2016 at 7:03 PM
WRENCHTECH
  • 20,761 POSTS
You still need to check the firing order. http://i1198.photobucket.com/albums/aa448/Wrenchtech/91037538.jpg.gif https://www.2carpros.com/images/external/94760148.jpg.gif Once the firing order is verified, see what the fuel pressure is with a gauge.
Jan 4, 2016 at 10:20 PM
DMSTILL
cool thank u will do
Jan 5, 2016 at 3:04 AM
