Runs poorly
127,500 MILES • 5.4L • V8 • 4WD • AUTOMATIC
1FORDMAN
Missing at idle and driving speed. set no codes.
Nov 7, 2017 at 8:59 AM
  • 110,248 POSTS
If there are no codes, then it is not ignition related. Check to make sure the fuel injectors are working/getting power. Also, you may want to disconnect one coil pack at a time to see which one does not make a difference. That way you will know which cylinder is causing the problem. Once that is determined, then check the injector/compression in that cylinder.
Nov 7, 2017 at 10:58 AM
1FORDMAN
I have disconnect coils does not make difference. ran compression, the missing is less than five seconds.
Nov 7, 2017 at 10:45 PM
  • 55,721 POSTS
So does the engine have good compression in all cyclins? Here is a guide to help you get the job done.
Please run this test and get back to us.
Cheers, Ken
Nov 10, 2017 at 2:51 AM
