2008 Ford F250 dtc code
2008 FORD F-250
16,050 MILES • V8 • 4WD • AUTOMATIC
GARCHEY2000
sowing code p0605.....running rough....ford delaer states not under warranty because of the code....problem is pcm...delaer states needs replaced.. question isnt the p0605 a vague code
Feb 17, 2009 at 5:10 AM
MERLIN2021
  • 17,250 POSTS
Your Dealer is lying to you! The PCM is considered an EMISSIONS part and as such is waranteed for 80,000 miles, P0605= internal control module read only memory (ROM} Error. PCM should be replaced. Call Ford directly, or NTHSA at 1-888-327-4236
Feb 17, 2009 at 5:25 AM
BMRFIXIT
  • 19,053 POSTS
PCM need to be reprogrammed
P0605 flash and program the PCM
Feb 17, 2009 at 5:39 AM
