Run hot if standing still
144,000 MILES
LEWIS HALEY
Car runs hot if sitting, pull off and it starts to cool.
Oct 6, 2016 at 12:43 AM
HMAC300
  • 48,601 POSTS
check your fuses and cooling fan relays under hood fuse box that may be the problem unless it runs hotter than normal when moving down road. also check coolant level if low then fill to full and have it pressure tested for a head gasket leak.
Oct 6, 2016 at 12:51 AM
