Runs and shuts down
15,000 MILES • 6 CYL • 4WD
DMILVAE
  • 11 POSTS
Motor runs and shuts off after 2-3 minutes.
Aug 19, 2019 at 1:02 AM
Good morning,
Does it start right back up or do you have to wait a while for it to start?
https://www.2carpros.com/articles/engine-stalls
Aug 19, 2019 at 1:10 AM
DMILVAE
  • 11 POSTS
It starts right back up.
Aug 19, 2019 at 1:14 AM
Okay, good possibility it is the crank sensor. It is common for failing like this and restarting right away..
I attached a picture of the location for you.
The Crankshaft Position (CKP) sensor is mounted into the right rear side of the cylinder block. It is positioned and bolted into a machined hole.
1. Raise vehicle.
2. Disconnect sensor electrical connector.
3. Remove sensor mounting bolt.
4. Carefully remove sensor from cylinder block in a rocking and twisting action.
5. Check condition of sensor O-ring.
INSTALLATION
1. Clean out machined hole in engine block.
2. Apply a small amount of engine oil to sensor O-ring.
3. Install sensor into engine block with a slight rocking and twisting action.
CAUTION: Before tightening sensor mounting bolt, be sure sensor is completely flush to cylinder block. If sensor is not flush, damage to sensor mounting tang may result.
4. Install mounting bolt and tighten to 28 Nm (21 ft. lbs.) torque.
5. Connect electrical connector to sensor.
6. Lower vehicle.
Aug 19, 2019 at 1:23 AM
DMILVAE
  • 11 POSTS
Thanks, I will try that.
Aug 19, 2019 at 2:01 AM
You are welcome.
Always glad to help.
Aug 19, 2019 at 2:13 AM
DMILVAE
  • 11 POSTS
I will let you know If this fixes the problem.
Aug 19, 2019 at 2:14 AM
Sounds good.
Aug 19, 2019 at 2:18 AM
DMILVAE
  • 11 POSTS
That fixed the problem. thank you
Aug 20, 2019 at 10:23 PM
You are welcome.
Aug 21, 2019 at 4:55 AM
