Rough running sputter and stall
195,000 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
BAT601
Car runs rough and sputters, stall when warm at low rpm and idle. speedometer not working. replaced, plugs, wires, etc. cleaned EGR and ports, upper intake and throttle body housing...
Mar 30, 2021 at 8:13 PM
  • 55,612 POSTS
The distributor goes out all the time in these cars. Do you have a check engine light on? if so lets use this guide to check the codes:
and
https://www.2carpros.com/articles/engine-stalls
Can you remove the distributor cap and look for rust colored dust inside this is a sure sign the unit is going bad. Let us know what happens and please upload pictures or videos of the problem.
Apr 1, 2021 at 4:55 AM
