Rubber burning smell
150,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
NOMISDARF
Smells like rubber burning and smoke comes out from under the hood then it starts losing power until I have to stop. But, after it sits or cools for fifteen to twenty minutes it goes again no problem, but ten minutes later it does it again. Someday's it does not do it at all.
May 19, 2018 at 9:05 AM
  • 55,721 POSTS
The fact that the engine gets hot and then shut off and you can smell it says to me engine overheating or the catalytic converter is partially plugged. Here are two guides to help you test and confirm the issue:
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
and
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Please run down these guides and diagrams and report back.
Cheers, Ken
May 20, 2018 at 11:17 AM
