power steering fluid is going back into the reservoir and it is leaking under the cap
169,000 MILES • 3.0L • 6 CYL • FWD • AUTOMATIC
RFTS10
  • 6 POSTS
I have a power steering problem. It looks like fluid is returning into a reservoir making a bubbles and leaks under the cap and pump is making ugly noise before it has warmed up.
Dec 6, 2016 at 10:11 AM
HMAC300
  • 48,601 POSTS
make sure power steering pump is full then try bleeding air by turning to lock one way and holding for thirty seconds then do the same in other direction. do this five times then check fluid and only use power steering fluid not transmission fluid. it may be the valve in pump making noise though.
Dec 6, 2016 at 11:11 PM
RFTS10
  • 6 POSTS
I m back with a power steering problem, after solution I got didn't solved the ps leak. this time I'm going to get more info to you. so, four months ago PS pump replaced , noticed leak ,two weeks later cooling fan replaced ,leaking again ,return car back to shop and they replaced ps pressure hose after couple days notice a leak again more and more I used car some time with leaking fluid every time I drive so finally went to a toyota dealer for check up, they told me its a ps return hose leak I looked it couldn't notice it's leaking. When I turn the car on ps fluid into reservoir start bubbling so much ,going up to the cap and spilling out under the cap, seem happened after I try bleeding air
Dec 12, 2016 at 9:34 AM
  • 55,673 POSTS
It sounds like you have a power rack and pinion selector valve going out and it is blocking the flow of the fluid. This happens after the pump goes out because of the metal from the old pump gets stuck in the valve.
Dec 12, 2016 at 1:10 PM
RFTS10
  • 6 POSTS
if this is a problem what is a solution to fix that?
Dec 13, 2016 at 9:11 AM
  • 55,673 POSTS
You must replace the rack and pinion.
Dec 13, 2016 at 9:22 AM
RFTS10
  • 6 POSTS
is the shop that replaced ps pump to blame for this happened r they respanseble for ?
Dec 19, 2016 at 8:17 AM
HMAC300
  • 48,601 POSTS
something like this I would say no due to it being the rack and not the pump if it was doing the same thing.
Dec 19, 2016 at 8:58 AM
RFTS10
  • 6 POSTS
hi,I m back again with a same ps problem and another information that can halp to solve it. so I did take a look at this one more time and I notise that all this happening only when the car is cold, after car wormed up and iset a fluid to normal level everything looked normal drived car for a few miles turn it off for one hour than drive again a few miles check fluid level was fine and no bubbling at all time, but in the morning turn the car on check,all same problem again.
Jan 5, 2017 at 11:33 AM
DOCHAGERTY
  • 9,606 POSTS
The "owners" of this site have chosen to screw the experts that are NOT volunteers by paying them $.50 per answer. They are operating out of Dana point in Ca. and that can't be cheap, but they are!
Jan 5, 2017 at 11:53 AM
RFTS10
  • 6 POSTS
I m not sure what is all this mean u talking about
Jan 6, 2017 at 6:47 AM
HMAC300
  • 48,601 POSTS
disregard what doc haggerty says . It probably is still the rack gone bad it's the part eh column connects to and goes to turn the car.
Jan 6, 2017 at 7:16 AM
