How to remove and replace the starter?
253,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
JONSOLOW13
  • 133 POSTS
Can you send me step by step instructions on removing and replacing the starter motor?
Thanks as always,
Jon
Nov 17, 2023 at 1:19 PM
  • 110,251 POSTS
As far as replacing the starter motor, here is a link that explains in general how it's done. This is to help get you started.
If you look below, the directions specific to this vehicle are listed.
Let me know if this helps.
joe
Nov 17, 2023 at 2:21 PM
JONSOLOW13
  • 133 POSTS
Thanks, Joe!!!
Nov 18, 2023 at 10:32 AM
  • 110,251 POSTS
No problem whatsoever. I hope it helps. Make sure before starting that you disconnect the battery negative terminal.
If you have questions or need help, let me know. Also, feel free to come back anytime in the future.
Nov 18, 2023 at 1:54 PM
