RPM's go up and the car will slowly accelerate and will make a noise sounding like metal scraping
141,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
ZSANTI14
Usually when I press the gas going straight, RPM's will go up to 5000 RPM's, however under 10 mph. When I turn left or right, the car doesn't seem to accelerate at all not even slowly hardly. The car will make a noise where it sounds like something is scraping is against something.
Oct 22, 2019 at 2:32 PM
Good morning,
Can you upload a video of the noise for me to hear?
As far as the slipping, did you verify the fluid level?
How long since the fluid and filter was changed? A clogged filter will cause this issue as well.
Oct 22, 2019 at 9:53 PM
ZSANTI14
Yes of course. the first video is an example of the rpm's going up while I press the gas pedal kind of slowly. The second will be the noise I was talking about. It’s kinda faint I have to listen close to hear it. Sorry there were other cars in the area.
Oct 23, 2019 at 2:07 AM
it sounds like it is starving for fluid from a clogged filter in the transmission.
I would start by changing the fluid and filter and see if there is any debris in the bottom of the pan.
Oct 23, 2019 at 4:19 AM
ZSANTI14
I would also like to add that I have had a drop in fuel economy. I’ve only driven 42 miles and I had lost a quarter of a tank. My mpg on the highway is supposed to be 28-29 mph.
Oct 23, 2019 at 4:21 AM
That is because the transmission is not working correctly. The engine has to run at a higher RPM. That burns the additional fuel.
Oct 23, 2019 at 4:23 AM
