RPMs dropping at low speeds while driving causing the car to shut down?
176,000 MILES
MINDYB05
I was driving at about 25 to 35 MPH, and my RPMs went to zero and back to 2 quickly a couple times then my car quit. It started back and drove normal until this morning it did this again and wouldn't start back. I had a diagnostic scan run on it and it came back with a crank position sensor which I had replaced immediately. When they finished, I drove it home and ran perfectly. I waited about 2 hours tried to drive it again and the RPMs started doing the same thing again, so I took it back home and didn't drive it again.
Mar 5, 2025 at 8:39 AM
  • 110,251 POSTS
We need to determine what is missing, ignition spark or fuel. A faulty part may have been installed, so here is what I need you to do.
First, see if the engine starts if you use starting fluid. If it starts and then stalls, we know it is a fuel-related issue. If there is no change, we need to check for an ignition spark.
Here is a link that explains how that is done:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
If you find there is no spark, have the crankshaft position sensor connector checked or have them replace the sensor.
Let me know what you find.
Mar 6, 2025 at 10:41 AM
