rpm's dropping and recovering
130,000 MILES • 3.1L • V6 • 2WD • AUTOMATIC
JRLAG
My wife called me this morning concerning her car listed above, I believe it is the 3.1L engine but will confirm that later if it makes a difference. She was driving down the highway when suddenly she said the tachometer dropped to 0 and then recovered a second later. She said it "felt" like the car was shifting very hard, and that it did this multiple times. She pulled over into a parking lot and even when in park, it would continue to drop to 0 and recover. I am asking for some opinions, to me it sounds like fuel pump or fuel pressure problems (maybe even a clogged filter?). I am open to suggestions on what others may think it could be. I just hope it is not the fuel pump because those are a pain to replace. TIA.
Jan 12, 2018 at 5:22 AM
Good morning.
Yes, it sounds like a failing fuel pump. You need to get a tester and test the actual pressure. there is a tap on the fuel rail by the power steering pump. you can rent a tester at a parts store.
Jan 12, 2018 at 7:57 PM
JRLAG
I just uploaded a video showing it while idling in a parking lot. I will see if I can go rent the tester today and get back to you. I will probably hook it up to check for any thrown codes but the check engine light is not on. Just want to be thorough. Thanks!
Jan 12, 2018 at 10:23 PM
JRLAG
Well I hooked up the pressure gauge and it read 35 consistent. Reving the engine fluctuated very slightly but always returned to 35..... maybe it’s not as bad as I thought? Gonna add heat with fuel injector cleaner to see if it’s just bad gas
Jan 14, 2018 at 12:49 PM
Ok, the spec is 41-47lbs for the pressure. 35 is too low. you need a fuel pump.
Jan 15, 2018 at 6:43 AM
JRLAG
Could it also be the regulator not working correctly? I appreciate your responses ASEMASTER
Jan 15, 2018 at 1:29 PM
Glad to help
You can try clamping off the return line to the tank and re test but regulator failures are rare.
Jan 15, 2018 at 6:23 PM
