Rpm's fluctuate
136,000 MILES • 5.0L • V8 • 4WD • AUTOMATIC
JSALZ
  • 13 POSTS
Start truck up rpm's go up to 2000 rpm's, then drop down to 1500 rpm's and then goes down to 900 rpm's. when put into reverse and drive I have it set to ten degrees BTDC, then it goes up to 18 to 25 with spout connector in, are the rpm's supposed to be in that range?
Mar 2, 2017 at 8:12 AM
HMAC300
  • 48,601 POSTS
try cleaning throttle plate on both sides and shaft area and IAC hole with choke cleaner. check for a vacuum leak and broken grommets on valve covers etc.
Mar 2, 2017 at 11:24 PM
  • 55,732 POSTS
Hey JSALZ,
I have seen where a worn distributor drive gear will cause the problem you are describing, can you remove the distributor and look for excessive wear please.
Best, Ken
Mar 6, 2017 at 2:51 AM
JSALZ
  • 13 POSTS
The distributors new got it up and running, thanks!
Mar 6, 2017 at 10:17 AM
  • 55,732 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Best, Ken
Mar 7, 2017 at 3:17 AM
