RPM surging
190,000 MILES • 6 CYL • 2WD • AUTOMATIC
PP270
The rpm's surge when accelerating fast between first and second and second and third gears. If you accelerate slow there is no issue. Any thoughts as to the problem?
Jan 15, 2019 at 11:39 PM
Good afternoon,
I would suspect a possible clogged catalytic converter. The back pressure needs to be tested to verify if it is the issue.
https://www.2carpros.com/articles/engine-surges
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Jan 16, 2019 at 1:25 AM
