Engine light on and do not have power go up to 60 barley rpm stay at 2,1/2 ?
May 2, 2017 at 1:46 AM
HMAC300
✓Experienced Mechanic
scan for codes and check fuel pressure with a gauge you may need an adapter auto parts rent it. pump is a high failure rate with older cars. and you need to see what the code is making the check engine light come on. See link for fuel pressure. https://www.2carpros.com/articles/how-to-check-fuel-system-pressure-and-regulator
