Rpm gauge sensor location
176,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
MICHAEL P WOODFINE
  • 8 POSTS
My car currently has no rpm sensor in it and i bought one, so i am wondering where does it go and how to install? It is an OEM rpm.
Feb 8, 2018 at 7:50 AM
CARADIODOC
  • 34,414 POSTS
Never heard of such a sensor. Does your engine run now? What kind of problem are you trying to solve?
Feb 8, 2018 at 7:58 AM
MICHAEL P WOODFINE
  • 8 POSTS
I had it mixed up with something else sorry but the sensor for my tachometer. My rpm gauge does not work at all as it does not have this sensor in.
Feb 8, 2018 at 9:42 AM
CARADIODOC
  • 34,414 POSTS
If the engine is running it sounds like the cluster has gone out. Here is the location of the sensor which is the crankshaft position sensor.
1 - Fuel Injector 1
2 - Fuel Injector 2
3 - Fuel Injector 3
4 - Manifold Absolute Pressure (MAP) Sensor
5 - Fuel Injector 4
6 - Evaporative Emission (EVAP) Canister Purge Solenoid
7 - Camshaft Position (CMP) Sensor - Intake
8 - Knock Sensor (KS)
9 - Engine Oil Pressure (EOP) Switch
10 - Crankshaft Position (CKP) Sensor
11 - Starter Solenoid
12 - Starter
13 - Intake Manifold
Feb 8, 2018 at 10:11 AM
VJDESIGNS07
I have a 2007 manual cobalt ls. My clutch slave cylinder n master were replaced. Now my tac gauge isn't working. My new starter replaced 2 months ago, now is slow to crank. I was hoping is get something from the answer.
Sep 16, 2019 at 4:32 AM
  • 55,743 POSTS
Please post your new question here, you must be logged in.
Cheers, Ken
Sep 16, 2019 at 4:40 AM
