High RPM
2004 FIAT
75,000 MILES • 1.6L • 2WD • MANUAL
PETER MOUNEER MARZOUK
While the car is neutral the rpm rises to 3000 and never goes down. I turned off the car and turned it on, the rpm is 900, but when i accelerate to 4000 the rpm stops on 3000 again. what should i do?
Jul 23, 2017 at 4:46 AM
  • 55,766 POSTS
It sounds like you have a throttle actuator that has gone bad or a large vacuum leak. Here are a couple of guides to help you see what's going on.
and
https://www.2carpros.com/articles/engine-idles-too-high
and you should scan for codes.
Cheers, Ken
Jul 24, 2017 at 7:52 AM
