2000 Other Fiat Models Punto Wont start
2000 FIAT
50,000 MILES • 4 CYL • 2WD • MANUAL
KEN-IN-KILDARE
Fiat Punto not starting. Not even turning over. lights, radio working. Tried jump leads and nothing happened. the clock on dash goes to zero every time i try to start. Is the battery knackered? It has been intermittent but now completely dead
Apr 14, 2008 at 7:58 PM
MINIME1
First check battery voltage with a volt meter, a fully charged battery should read about 12.6/12.7v, if less than 12v your battery is discharged and needs fully charged up, or if it does'nt hold a charge, replaced.
Check the earth connections from your battery and make sure the connections are clean and tight.
If your engine still fails to turn over then you may have to check the starter circuit i.e. fuses, relay, starter solonoid, starter motor, ignition switch and associated wiring for broken or loose connections etc.
Good luck.
Apr 19, 2008 at 8:25 AM
