tachometer not working properly
1,411,689 MILES • 2.0L • 4 CYL • TURBO • 2WD • AUTOMATIC
RAMAH DAN AGUAM
Engine runs okay, but usually the tachometer would go to zero without any change in the engines run then tachometer would go back to normal.
Oct 12, 2018 at 1:57 PM
  • 55,746 POSTS
This can happen when the ignition system is back feeding in the tachometer system. I would start with a full tune up, plugs throttle bore service etc. Here is a guide to help us get started, use OEM parts.
https://www.2carpros.com/articles/how-to-tune-up-a-car-engine
Cheers, Ken
Oct 15, 2018 at 4:45 AM
