rpm low in starting any time and gear down shifting
2007 CHEVROLET AVEO
155,000 MILES • 1.2L • 4 CYL • 2WD • MANUAL
GEORGEJINU
My car is starting any time the rpm is going too low or engine off and i give the accelerater raise five seconds and remove the leg from accelerater,the rpm going normaly up and again going too down after rpm coming normal.Then i drive the car some times gear down shifting the rpm is coming too low or engine automaticaly off.please give me an answer
Mar 30, 2014 at 1:58 AM
HMAC300
  • 48,601 POSTS
try cleaning throttle plateon both sides and iac hole with choke cleaner
Mar 30, 2014 at 2:33 AM
GEORGEJINU
this drive belt center groove damage and i think belt not rotate properly.
Mar 30, 2014 at 3:33 AM
HMAC300
  • 48,601 POSTS
recommended belt an dtensioner replacement is 60,000 miles
Mar 30, 2014 at 4:15 AM
