Low power
175,800 MILES • 2.5L • 4 CYL • 4WD • AUTOMATIC
STEVEN8200
Hello, I have recently bought the car listed above RS model used. It started having a problem with the rpm's jumping down anywhere from 500 rpm to 2,000 rpm depending on how much I press the gas pedal past a certain point as long as I only press the gas far enough to hold about 35-40 mph on a straight away it's fine but any farther or going uphill with the pedal pressed to maintain any more than about 20 mph the rpm's drop. There's also a white smoke coming from under the car where what seems to be near the start of the exhaust system. I was wondering if you know what the problem is and/or a way to fix it? please and thank you.
Aug 4, 2019 at 5:13 AM
  • 55,721 POSTS
This sounds like you have a clogged catalytic converter. To be sure this guide will show you how to test it:
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
This guide can help as well:
https://www.2carpros.com/articles/engine-has-low-power-output
Aug 5, 2019 at 9:15 AM
