RPM Guage works intermittently, then stops, then works intermittently. It gives a code (PO725) Engine input speed or something to that affect. I erased codes three times, usually comes back on in a few minutes, but after I erased code last night I drove back and forth, roughly 3- 4 blocks code did not come back on, neither did RPM gauge leave zero.
Since P0725 Is a generic code, Is that the same meaning as VSS (Variable Speed Sensor)?
If so, I need to locate it for testing, and receive proper instructions for testing if I am on the right track.
Wade
Wade
Apr 9, 2014 at 11:57 PM
