RPM fluctuates at idle
215,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
FOX12
When sitting at a light the RPM will be at seven hundred RPM then will decrease to six then five then drop to three hundred then it will fluctuate between two hundred RPM and three hundred RPM then the engine will shutdown. It is hard to start up again but it will start. I have to press down on the gas pedal and let off the gas pedal to be able to get home. Mechanic clean Idle air control actuator ran fine for two weeks.
Jul 17, 2018 at 4:22 PM
