When idling everything is fine. When I shift into gear rpm drops under 500 and to 0. The engine then shuts off and I have to restart. If I press gas to increase RPMs before/while shifting, the rpm still drops but not low enough for the engine to shut off and I can drive normally until I come to a stop. The car is fine at high speeds and when floored. I have replaced the engine and transmission mounts, one was broken, as well as the spark plugs, engine coils, and fuel pump. The problem still persists.
Jul 2, 2024 at 11:15 AM
