This is a carburated vehicle with an electric fuel pump mounted along the frame rail. Car will start up properly and run at the faster rpm's until warmed. Then the rpm's will subside to the proper setting, around 800-900. At this point it will seemingly run forever until you advance the rpm's at 2,500-3,000 rpm's the vehicle will only run about 15-20 seconds or less... then the rpm's just start to slow down . If you do not release your foot from that position it will completely shut off. If you ease up to the idle it will momentarily stutter and then resume idling as per normal again. If it does shut off before you ease up it will restart after just a few seconds.. don't have to wait long.. On some occasions it has also died after only idling for 10-20 minutes or so, with no acceleration at all during that time.
I have a new fuel filter back by the tank, a new one in-line just before the carburetor, and a new fuel pump. The fuel entering the filter just before the carburetor shows more than adequate fuel in the filter, and also plenty arriving into the filter from the pump... it never runs dry or even low.. so I don't believe that is the issue. The carburetor was rebuilt last year at this time and it's had a bit of miles put on it since then. Both of the float sight-glass levels are right on the mark dead center while running and appear to remain there throughout....
I've also attempted running the car with and without the gas cap on, since I noticed a fair amount of pressure escaping whenever I removed the cap. This did not seem to make any difference still faltering on the rpm's either way...
What else could it be?
Dec 6, 2019 at 3:02 AM
