On the first start up in the morning, the RPMs goes approximately 2,000 which is normal however when i rev the engine the RPMs drops and the engine shakes it like when you put brake clean in the intake and start the car, and ounce white smoke with the smell of gas came out the engine (i think i have exhaust leak). it's like it flooded with gas. no codes, no check engine light and when the car acted up the check engine light did not flash. I checked the coolant level it's still same level and the oil is not milky.
Feb 2, 2022 at 6:01 AM
