rpm are low and shut off when drving
144,000 MILES • 2.3L • 4 CYL • FWD • AUTOMATIC
SEK436
i will drive around for a little then shut off the car then I try to start it,it cracking but stays off for more the 10 min, then it makes a clicking noise then my hot cold gauge goes to the middle then I know it'd good to start .I change the alternator battery fuel filter fuel pump spark plugs spark plug wires thermostat and still doing the same thing oh yeah my rpms Are low
before and after
May 29, 2015 at 8:49 AM
  • 110,248 POSTS
Based on your description, it sounds like a bad fuel pump relay. When it doesn't start, try using starting fluid to see if it will run for a couple seconds. If it does, then fuel isn't getting to the engine. The clicking you are hearing may be the relay engaging the fuel pump and allowing it to start.
May 29, 2015 at 1:31 PM
